iOS Connection Security
To ensure the integrity of the corporate firewall and to provide an additional layer of security for data flowing between the mobile device and the MobiControl Deployment Server(s) and Deployment Server(s) over public networks, SSL Communication Mode is available to provide encrypted communication. SSL provides the additional benefit of standards-based authentication and encryption security.
To configure the iOS devices to connect to a network enable the Connection Security Policy and follow the steps for the connection type desired.
Configure WiFi
Configure SSL device settings dialog box
Item Description
Wireless Network Identifier Enter the SSID if the Wireless network the device connects to
Hidden Network Specify if the SSID being configured is hidden or not
Wireless Network Security Type Select the Network Security type used by the Wireless Access Point
Wireless Network Password Enter the Password required in order to connect to the Wireless Network
Configure APN
MobiControl can setup an APN connection for the device to connect to the Internet.
Item Description
Access Point Name Enter the SSID if the Wireless network the device connects to
APN Connection Username Select the Network Security type used by the Wireless Access Point
APN Connection Password Enter the Password required in order to connect to the Wireless Network
Server Address Enter the Server Address and port for the APN connection
Configure VPN
Some corporations require the use of a VPN to connect to their network.
Item Description
Connection Name Provide a friendly name for the connection on the device
Domain Name Enter the Domain Name the connection is going to use to authenticate
Connection Type Select the Connection Type the VPN is going to use to connect
User Authentication Account Enter the User name for the VPN connection
User Authentication Type Select the Authentication Type for the VPN Connection
Server Name or IP Enter the VPN Server Host Name, DNS, or IP
Proxy If required, enter the Proxy connection information. Enter the Proxy Server Address, Port, Username and Password
Shared Secret Specify a secret that will be provided to your users in order to connect to the VPN Connection
Configure Certificates
Some companies will require additional APNS Certificates.
In the case above, the Device Agent stores the MobiControl Root CA Certificate in the operating system's trusted root certificate store.
Add Certificate dialog box
